Zero Touch Fabric Configuration automatically configures the Shortest Path Bridging (SPB) and Intermediate System-to-Intermediate System (IS-IS) infrastructure to enable Fabric architecture on a switch. The system initializes the following items after you start the switch in Zero Touch Fabric Configuration mode:
Parameter
Default value
SPBM instance
1
Primary B-VLAN
4051
Secondary B-VLAN
4052
Manual area
Initialize to 00.1515.fee1.900d.1515.fee1.900d
Note:
You can change the manual area dynamically, without disabling IS-IS, only when the area is the Zero Touch Fabric Configuration area.
When IS-IS is enabled, you cannot delete the last manual area.
Auto-sense onboarding I-SID
15999999
